Discuss any advice on fireman switches in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Never done one but I would assume it is some sort of contactor arrangement. I think they are only required for external neon signage aren't they?
I'm presuming if it just switches off a certain circuit it would be wired to a shunt trip device. I could be wrong though.
Never actually fitted one but i do have a firemans key thats a cross between a socket extension bar and a allen key. Its useful for electric gates on carparks. A good way of getting in when you dont have a fob
it is s firmans switch in a block of flats i thought they just dropped the magnet from the door so they can get in but does much more the contactors would make sence but does it kill the power to the whole block
They used to be popular...as mentioned,an isolator for external,powered items,such as signage,barbers poles,etc.
They had an eyed lever,which was operated by a firemans standard pry (looks like a beefeaters pike)
A lot of yankee equipment,including a pool boiler i recently fiddled with,had a link included,in the wiring,to which the fireman's switch would be connected.
Thank you for your question,young apprentice,now all you need to complete today's lesson,is a sense of humour ;)
hi there iam just looking for a little advice on fireman switches on how they are wired and how they disconnect power cant find anything so just a little post here thanks for your time
Via a shunt trip or contactor arrangement
yeah say we are using contactors has everything to be de-energised via the contactor or is it only certain things to be de-energised the ones iam doing are diffrent than normal... as they need a constant feed to the flat door for it to open so its normally an open circuit that is closed when the switch is opperated but the client wants it so the door cant be left opend.
I would have thought that flat doors had to fail safe.
What happens if there is a power cut and the doors can't open? Or do they have battery back-up?
Reply to any advice on fireman switches in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, I’ve purchased a Ring Spotlight camera and decided to remove the old spotlight that’s currently installed on the house we recently...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
