- Reaction score
- 8,754
I wasn't quite sure where to post this random question, but I'm fairly sure that some of the geniuses on this forum will have some ideas.
I'm trying to find a way of re-magnetising some 50 year old small magnets used in open-frame motors for model railway locomotives.
There is a machine available for quite a chunk of change specifically for this purpose. I'm not quite ready to part with the £150 yet is it feels like it shouldn't be too hard to do another way.
A physicist friend says the concept is simple enough - basically put the magnet between two strong electro-magnets. Or put the magnet inside a solenoid and give it "lots of amps".
I've done a few experiments with a current-limiting car battery charger (10A limit) and a few home made coils and the concept is certainly working but not quite well enough; the magnet ends up stronger but not as strong as it needs to be. In the pursuit of more amps I also very carefully tried an 18v lithium (cheap parkside) battery which was better again, but still not good enough.
I'm thinking the inefficiencies of my own attempts at coil building are the main problem and I should buy some commerical electro-magnets. The question is, how strong? Some reasonably priced 12v units that I've seen say they will lift 50N/500 Kg. Does anyone have a view as to whether they would create a strong enough field for my purpose?
For info, this is the rather lovely machine that I'm trying to avoid buying:
Some people do just buy new replacement Neodymium magnets but that isn't anywhere near as much fun!
Any thoughts most welcome (other than I should get out more!)
- TL;DR
- How strong an electro-magnet do I need to re-magnetise a permanent magnet?
