Discuss Any idea what this DB circuit symbol is? in the UK Electrical Forum area at ElectriciansForums.net
Was at a job for a different reason, but saw this and was curious.
Asked the tenant, and they didn't know what it was for either.
Any ideas? Its obviously come from a Hager DB sticker pack.
I'm guessing as its a 6A, smoke alarm?
Smoke alarm would be my guess, but then I found this image:
Which has a different symbol far left which I'd guess is smoke alarm, or maybe heat alarm?
Given the standards on everything else, you'd think they'd have come up with a standard for symbols to be used on CU by now (At £150 per copy, naturally)
What the heck is Circuit 3 ? Dustbin power ?
No idea - waste disposal maybe, but who runs that separately? Pop up sockets? seems a bit too niche to have a symbol....
Or maybe it's meant to be an immersion tank? That at least would make sense on a 16A, but not a great image...
Central vacuum cleaner? The ones that have a ducted outlet in the walls you plug hoses into.... or could simply be a hot water tank??
why don’t they use the printed stickers with words instead.... then you get to know which upstairs lights, downstairs light etc.... not just “lights”
Most electricians writing is worse than a doctor, never seen a legible written one yet. Tin hat on.
i have to admit to neat writing. my lad on the other hand.... his looks like it's done by a drunken spider with parkinsons.
Reply to Any idea what this DB circuit symbol is? in the UK Electrical Forum area at ElectriciansForums.net
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi all, Just wondering what the general situation is with other people on smaller jobs, do you give a quote or estimate to the client before you...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
