Discuss Any idea what this is? in the Electrical Forum area at ElectriciansForums.net
There is no immediate danger....
That depends on where those grey tails are going.... In through the wall to feed the consumer unit, yes. that's fine.... Cut off and floating about in the box... live.... not so fine.
Liverpool. The door's been nicked. Have a word with @telectrix about it
True, I made an assumption that as the op knew the meter was on the other side of the wall then the tails were attached to it.
however I would probably be in contact with your local DNO to get them to fit a new door.
Reply to Any idea what this is? in the Electrical Forum area at ElectriciansForums.net
