Discuss Any last minute tips? in the UK Electrical Forum area at ElectriciansForums.net
R
Rauer
Well got my elecsa assessment on Tuesday any tips muscly appreciated , and anything you would recommend knowing religiously ( without having to refer to the bgb!!!)
Be confident in your testing and conduct, nobodys perfect...knowing everything, but as long as you know your job you should be fine bud.....Gudluck!!
Got my NICEIC assessment also on Tuesday, it's went ok for the last 4 years, so I'm hoping the same happens this year.
Just remember their not there to trick you. Just do things as you would any other day
good luck!
Chat about part p and what a farce it is he will forget about your assessment lol
Theres also an old thread on here questions to ask a scam assessor
Cheers guys , well this is my first assessment and decided to show them a board change on my brothers house, it's all tested out ok , there was no earth at a fitting that I had to sort and the bonding is all in 10mm so it's all good really , it's just the sort of questions that they will ask that worries me!
Hi,
I've just started a similar post and I think the best advice given to me was to ring them (elecsa) up and ask what they are looking for. When I rang mine they said I would be asked some questions about BS7671 and they also put my mind at rest as to what practical stuff they were looking for. I thought I would need to get a C.U change under my belt, but they said they would be happy seeing at least one new circuit rather than a full C.U change.
Give them a ring, be cheeky and ask.
From my Experience of elecsa, (no longer with them)
They asked a lot of questions on building regulations, electricians guide to building regs was his favourite book to see.
Definitions of IP ratings, and expected results when testing....
Pretty basic stuff really and he always said as long as you know where the info is I don't expect you to know it all!
So you'll be fine ;)
He will spend the first hour or so just getting a feel for your background and how you approach your work. Just make sure you have all your documentation to hand as he will have to record that it is all in order.
The other guys have pretty much covered what is expected, and most of what you will be asked is in the osg and the electricians guide to the building regs, so just keep reading them.
Of course it will be stressful (if it matters to you), but always double-check your answers if you are not sure by looking them up.
Oh, and make sure the CU has all 3 labels on it.
Make sure you review the check list they provided in the pack you got sent. What they are expecting to see is detailed, then they look at your "job" certificate, invoice and my assessor likes to see a couple of estimates too.
Just remembered that my assessor asked for proof that I had notified jobs, luckily I had printed out the details for each one.
Also looked through estimates/quotes to see if i had specified the style of fitting, white plastic / Georgian brass etc.
Surely I don't need to do this yet as I only did the change on Thursday
No, you won't need to have notified anything before your assessment with Elecsa.
Ok, one last time....
You are "supposed" to notify LBC in advance that you will be carrying out notifiable work (along with a large fee). Then they come and see what you are up to. Once you complete the work, LBC come back out and sign it off for you.
In reality, most LBC's are not interested, as they know that you will notify it yourself once you become part P registered. NOTE: They only allow this "bending" of the rules for assessment jobs.
I actually did things by the book and spoke to my LBC beforehand (foolishly, you might say), and they made a note that I was carrying out notifiable work for assessment purposes to cover me.
Just relax, and as long as you have done a good job, have all the relevant paperwork in place, and can find the answers in your books, then you will be fine :)
Remember....They WANT you to be in the club.
Reply to Any last minute tips? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Been popping onto there forums over the years and happy to have finally signed up. Got my AM2E assessment coming up, the final hurdle...
Every time i go to do this, even with correctly fitting sleeving, it seems to be a right **********")£"$$* of a job getting all three in snugly...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
I am an experienced electrical engineer consultant in building services, and I am looking to expand my professional horizons by taking on side...
So I'm starting out a new rig and I'm fresh out of college with my level 3 without any experience and I think that I need to still have the...
