Discuss Any recommendations for shallow, fire rated, insulation coverable, integrated downlights in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
As in the title.
I need downlights that can be covered in insulation, fire rated and integrated.
Preferably quite shallow as well!
I'm struggling a bit to meet all the above criteria :(.
Cheers guys.
JCC V50. 2" height and coverable.
or....
or....
Cheers Tel,
So I'm guessing they need a separate led driver? Also, can they be covered in insulation?
or....
Cheers again Tel.
Customer has now added another criteria!!!
They have to be dimmable!
I don't think the ones in your link are?
the JCC V50s are dimmable. and switchable either warm white or cool white.
I believe the enlite E8 are coverable too and come in a dimmable format.
I use KSR QR10 mostly which are coverable and dimmable but come with a separate driver, which is not coverable. Not usually a problem though.
JCC V50 as others have said (irritation on registering batch codes, though), or Knightsbridge/ML RW6 range (either warm white, cool white, switchable (via wall switch), or "dim to warm").
Have installed about 30-40 of these over the past couple of years and (touch wood) not had a callback yet.
CEF do Enlite slim fit LED units, the driver is separate and I'm not sure of fire rating but they have decent lumens.
Thanks for all the replies chaps. I’ll have a browse through each of the links.
As in the title.
Cheers guys.
Collingwood H2 Lites. (They're also dimmable.) Not sure how shallow you need though.
[automerge]1575272901[/automerge]
Oops. See Lee beat me to it.
Reply to Any recommendations for shallow, fire rated, insulation coverable, integrated downlights in the UK Electrical Forum area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi there I’ve got some spots to install in some shelves being put up. This sounds very straight forward I know but I was only thinking, do they...
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
