- Reaction score
- 10
Hi Sparkys.I have a need for knowledge regarding a yamaha tdm 850.i have just done an engine swap like for like so i can rebuild the old engine,then re-install it later this year,it has normal 3phaze alternator and regulator/rectifier box.The 3pin connector where you unplug the alternator from the loom had been getting hot unbeknown to me,suspect dry soldered joints as the bikes 1993 model.it got so hot its partially melted the plug in connector.As its a sealed unit i decided to re-do the connections with 15A 'chock strip' type screw connectors then tuck them away in a IP rated enclosure,i marked the 3 cables so i knew which paired with which,And i meant to take a photograph so that when i replace the old engine i know which of the 3 cables goes with which,but like a clot in my enthusiasm to crack-on i forgot to take a pic !! dooohh !!,i have them paired up correctly in chock strip and it now runs cool to the touch but when i put the old engine back in i wont know which was th top one and which was bottom left&right...Question is does it matter which way round the 3 phases are connected to the reg/rectifier or will it still generate fine which everway round ( fingers crossed ) but if it will only work connected in a specific way how can i find which order to connect them in.I'm an ex-armature winder ( but not since 1980's) so have good general knowledge..Any help at all very much appreciated in advance.
Kind regards.
Mike.
Kind regards.
Mike.
