Advertisement - Content continues below
Discuss Any way I can get away with in the Electrical Forum area at ElectriciansForums.net
Hello guys
I need to install some external car charges outside in a car park on the wall.
Problem being is that the building has a PME system and there are no drawings of where the services are buried so I want to avoid using an earth steak.
Is there any way I can get away with not having to use an try system?
Test Meter - Forum Sponsors since 2007!
Pete999
Hello guys
Chris not sure what your last sentence means.
telectrix
Mentor
see this thread.might be worth a follow up.:
  • #4
sorry, i was trying to say is there a way i can get away with not using a TT rod for car chargers installed outside on a PME system. (very anxious about banging rods into the ground)
Pod point have a charger however the PME break detection device installed within is not to any BS standard to looks like a TT rod it is
Pete999
Hire one of these jobbies
Strima
As I said in your other thread, hand excavation and conductive concrete.
Strima
Pete999
They’re ok but not that accurate and won’t detect plastic services etc. Also the user needs experience to understand the readings.
Should be OK if he can read, RTM, or if he can't read hire a firm that traces underground services, or use a couple of bent welding rods, I used to be a dab hand with those, especially water pipes.
Aico 3000 Range
Reply to Any way I can get away with in the Electrical Forum area at ElectriciansForums.net
Top Bottom
