Discuss Any way I can get away with in the UK Electrical Forum area at ElectriciansForums.net
Hello guys
I need to install some external car charges outside in a car park on the wall.
Problem being is that the building has a PME system and there are no drawings of where the services are buried so I want to avoid using an earth steak.
Is there any way I can get away with not having to use an try system?
Hello guys
Chris not sure what your last sentence means.
see this thread.might be worth a follow up.:
sorry, i was trying to say is there a way i can get away with not using a TT rod for car chargers installed outside on a PME system. (very anxious about banging rods into the ground)
Pod point have a charger however the PME break detection device installed within is not to any BS standard to looks like a TT rod it is
Hire one of these jobbies
As I said in your other thread, hand excavation and conductive concrete.
They’re ok but not that accurate and won’t detect plastic services etc. Also the user needs experience to understand the readings.
Should be OK if he can read, RTM, or if he can't read hire a firm that traces underground services, or use a couple of bent welding rods, I used to be a dab hand with those, especially water pipes.
Reply to Any way I can get away with in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wasn’t sure where to get some information, so I thought I’d ask the question here! FYI I have no electrical quals, I build custom...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
