• Welcome to the new forum. We're now hosted on ElectriciansForums.net rather than ElectriciansForums.co.uk - Chat about the forum upgrade by CLICKING HERE
Welcome to our Electrical Forum - We started out providing electrical advice just for the UK - But now we have specific advice for the USA too! - Register for free and share American Electrical Advice.
Discuss Anyone got experience in Maintenance on Stairlifts? in the Electrical Forum area at ElectriciansForums.net
Alan McMaster
New EF Member
Could be starting a new position with a stair lift company and wanting to know of anyone with experience in this sector to maybe give me some pointers. From what I have gathered there is 3 main PCBs that control the lifts, inverter for speed control and then motors and limit switches. Probably a lot more to it but these I would think would be the main issues.
Never really worked with PCBs before and there is training provided at the beginning, but Id like to get a headstart and get some learning in now so Im not just a nodding dog. Any references, books, videos or advice Im open to all suggestions.
Ive worked with motors and limit switches before, I can setup basic programs in Inverters and read fault codes from them, however its the PCBs that could be scary due to lack of knowledge.
Thanks in advance
A
Adam W
Chances are it's just a case of replacing the PCB depending on what the fault is, just as if your graphics card started playing up you'd just take it out and put a new one in instead of getting the multimeter and soldering iron out.
Alan McMaster
New EF Member
Been told I have to know why im replacing it and that would suggest testing the components? I would think its as simple as measuring across them and getting the resistance and checking against acceptable values?
They repair the PCB back at the workshop so it is just a matter of swapping them, but diagnosing the fault will be one my tasks so as to help speed up the repair by pin pointing the faulty component?
ruston
Respected Member
Usually the micro and limit switches are the first culprits to give problems . There are quite a few of them .
As Adam says a suspect PCB would not likely be repaired on the job.
I have only repaired a few and am no expert on various models .
Reactions: DPG
Wilko
Electrician's Arms
Hi Alan and welcome to the Forum. With any luck they'll have some training material for you and someone to work with too :) . Good luck with getting the job !
Alan McMaster
New EF Member
thanks for the welcome. Yeah have a few weeks training to begin with but want to impress as much as possible to stay in the job and to get out and about as soon as possible. Thanks for the replies as well.
Spoon
Forum Mentor
Don't worry about the PCB's. IMO they should have a maintenance manual telling you what outputs you should have and where on the PCB. This will tell you what is faulty.
Spoon
Forum Mentor
If you Google 'stair lift pcbs' you can look at some of the pbs's out there. Like this one.
Murdoch
Electrician's Arms
Is this a full time role?
Murdoch
Electrician's Arms
Just be wary of the area you will be expected to cover .
My late mother had a chair lift and when it stopped working the service company were a nightmare - rarely achieving their response times ....
Marvo
Admin and gender confused
Staff member
Admin
You won't be expected to work down to component level on control boards. You just need a wiring diagram that shows you the inputs and outputs and those would be what you'd be testing to establish if it needs replacement.
timbobelfast
Electrician's Arms
Thanks in advance
Normally if a PCB is knackered it is replaced from my point of view. Unless you are proficient with diagnosing, selecting and soldering the correct components like capacitors, psu, bridge rectifiers etc. The chances of doing this in someones house with workshop like equipment is unlikely.
Spoon
Forum Mentor
I very much doubt you will be responsible for changing components on these boards. By the looks of them, most of the components are surface mounted. Something that, if needs changing is better done in the right conditions, not in some ones home.
Electrician Talk
Electrical 2 Go - Electrical Supplier and Electrical Wholesalers
Electrical Insurance
ElectriciansForums.net (formerly known as ElectriciansForums.co.uk) was setup in April 2006 to provide free electrical advice to both professional and DIY electricians. Whether seeking advice for auto electrics, trying to find electrical installation condition reports (EICR) form downloads, or whether you're here just to talk to other electricians; we've been a first-choice website for tens of thousands of sparkies for well over a decade.
