Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Discuss Anyone have any ideas on how to remove a live broken screw from a meter in the Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Anyone got any ideas on how to get a live broken screw out of a meter?
pc1966
Supporter
You can get screw extractors like this:
https://uk.rs-online.com/web/p/screw-extractors/7798842/
However, aside from the obvious aspect of safe isolation before working on it, in practice it is hard to get out a screw that has been over-tightened to the point of breaking the head without breaking the extractor.
If I simply had to get the screw out then I would remove the meter, cut the tail that can't be removed, drill the cable to release some of the pressure, and then try a screw extractor on the head. Assuming it is successful, then try to source the correct replacement screw.
In reality a replacement meter is a much better and safer route, so speak to the DNO/electricity supplier about that as it is not the client's property to change.
freddo
Supporter
To get a screw extractor in there you would first have to use an end mill to flatten the remaining half of the screw, spot it with a centre drill, bore a hole in the centre, a left hand drill bit is best for this when trying to remove broken screws, then try the screw extractor. The meter would need to be clamped down in a drill press or mill to have any chance of success.
littlespark
It’s not live, it’s neutral.
either way, not an easy thing to fix.
Trainee? Should ask @Dan or another admin for access to the trainees section..
Might find some handy tips
Reactions: Dan
Status
Reply to Anyone have any ideas on how to remove a live broken screw from a meter in the Electrical Forum area at ElectriciansForums.net
