Discuss Anyone have any ideas on how to remove a live broken screw from a meter in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Anyone got any ideas on how to get a live broken screw out of a meter?
You can get screw extractors like this:
https://uk.rs-online.com/web/p/screw-extractors/7798842/
However, aside from the obvious aspect of safe isolation before working on it, in practice it is hard to get out a screw that has been over-tightened to the point of breaking the head without breaking the extractor.
If I simply had to get the screw out then I would remove the meter, cut the tail that can't be removed, drill the cable to release some of the pressure, and then try a screw extractor on the head. Assuming it is successful, then try to source the correct replacement screw.
In reality a replacement meter is a much better and safer route, so speak to the DNO/electricity supplier about that as it is not the client's property to change.
To get a screw extractor in there you would first have to use an end mill to flatten the remaining half of the screw, spot it with a centre drill, bore a hole in the centre, a left hand drill bit is best for this when trying to remove broken screws, then try the screw extractor. The meter would need to be clamped down in a drill press or mill to have any chance of success.
It’s not live, it’s neutral.
either way, not an easy thing to fix.
Trainee? Should ask @Dan or another admin for access to the trainees section..
Might find some handy tips
Reactions: Dan
Isn't the neutral consider to be live now days?
Yes, line and neutral are live as they carry current normally.
But live & line are used interchangeably and not always following that definition.
Not sure if line is preferred over phase though in correct terminology.
That is where the confusion starts, with switched live being called line or phase and visa versa, I reserve phase for the inputs from the meter.
A conductor should not be referred to as a phase conductor, it is a line conductor. Phase denotes a connection between lines. The IET or IEE recognised its incorrect use and amended the Regulations from phase to line.
Status
Reply to Anyone have any ideas on how to remove a live broken screw from a meter in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
