Discuss Anyone know anything about heating controls? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I have just swapped my ancient potterton room stat with a new Honeywell DT90E, just because there's now no argument about what temperature its at.
I have a a non condensing boiler with indirect heating via a coil thing (i think) which is unvented.
Its a Potterton Suprima 60L 78.15 Efficient D rated boiler which kicks out 17.6kW.
See link: Potterton Suprima 60L Gas - Boiler Efficiency Ratings
Reason for my concern and want to do something is because the gas bill for the last 4 weeks was £150, the last house it was only £35 per month ish, but this was 312 units, £150 of actual usage not guesstimated.
Anyway, see the photos below of what I have.
I have 15 Radiators and want to know if I can make it all wireless and have a stat in each room, so would want probably 8 room stats.
Can I do this with what I have? I have a TRV on each radiator, but what I want to know is, can I change them all for wireless and pair them all with the relevant radiators so that I can turn the heating up in one room and it opens the stat or something?
Do you see what im getting at?
2014-12-31 16.58.54.jpg2014-12-31 16.58.26.jpg2014-12-31 16.58.19.jpg2014-12-31 16.58.09.jpg
That is going to cost a lot in parts to do what you suggest. Also you could end up with your boiler running longer and using more gas . Your money would be better spent on improved insulation as Murdoch has suggested and going to a condensing boiler with compensating controls. I recommend Worcester CDI (sized accordingly) and FW100. Vailant also do one.
The house is only 14 years old, has cavity wall insulation, tons of loft insulation, everything you can possibly do.
What do you feel is causing my high gas bill?
I don't know if leaving the hot water on auto is going to be better / cheaper than leaving it on once / twice a day? Any ideas?
Whats the benefit of a condensing of the non condensing boiler? I don't know anything about them.
I think you need to be a registered, approved, trained installer to fit those....
I am a Honeywell approved installer having done their training course... But not on the Evohome, to be honest, I do not work with heating controls enough to be able to remember exactly how it all works.
Firstly the efficiency of that boiler isn't as good as modern alternatives.
But a few things to consider first before you go to any unnecessary expense are:-
Is the boiler installed in an unheated area, e.g garage or outhouse? the reason I ask is that the boiler may have a frost protection stat fitted. they are usually set at around 5 degrees C so it would be worth a check, if the temperature drops low (which it will this time of year) then the boiler will kick in on regular intervals when not in full use.
Try just turning down the TRV's in the rooms you do not use much, and keep the doors closed.
Check to see if the temperature of the heating from source (boiler) is not set too high. Many people have it wound right up causing scalding hot rads which is dangerous and totally unnecessary. The boiler will just constantly keep kicking in to maintain the flow temperature.
I noticed from your pictures that the hot water stat is set ok so are you timing your hot water, or is it regularly set to constant?
Efficiencies are much higher with a condensing boiler, but system design is also important as they only condense below the dew point (approx 55 degrees), modulating boilers condense for longer. Also how you use it, if your wife has the stat at 23 all the time, that will make a massive difference!!
Hmm, ill check about the frost thing, and having just looked at the temperature knob, its on Max..
Presumably if I turn this down will it not make a difference to the temperature of the water? Roughly where abouts should it be on the dial?
Thanks for the help everyone!
Condensing boilers are far more efficient and "more environmental friendly". They work on the basic principle of recovering as much as possible the lost heat ejected through the flue.
Your boiler stat controls the heat of the primary pipework. You have an S Plan arrangement. This indirectly heats your water via a Zone Valve through a coil in your cylinder. This is regulated by your cylinder thermostat. It would only affect water temp if you set boiler stat at a lower temp than cylinder stat.
ALWAYS check the meter the day your bill arrives or better still the day its read. And if its estimated make sure that you submit a reading.
It could simply be that they are estimating YOUR usage based on the previous people who may have liked living in a very warm house.
If its BG, and you have opted for monthly payments, be aware that they take the previous 12 months, allow for price increases and then divide by 11!
We had the opposite problem as our house had been empty for 18 months, so every quarter they tried to reduce our payments as they were recalculating using the "zero" values!!
Reply to Anyone know anything about heating controls? in the UK Electrical Forum area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
So I’ve been having this issue with my boiler for a while now, I’ve currently got one stat in the hall that when I turn it on it brings the...
Hi people, I’m new to the forum, first post so here goes. I’m wiring a heating control system and at the moment the customer wants as follows; A...
Basically, I am looking to find out how much the industry knows about Cranford Controls and what they do. Anyone willing to chat to me about this...
