Discuss Anyone know this cooker switch? in the Electrical Tools and Products area at ElectriciansForums.net
yeAH LOOKS like the bottom left terminal is burned out
you can probably pick up a near identical switch from any decent wholesalers
Surprised to not see any branding on the back of it, even the absolute tripe that is sold in Home Bargains has branding on the back of it
Is the cheap or expensive?
It’s quite expensive, yes, probably about a tenner above market average, especially given the fact that it’s deta.
The same switch is on eBay at 14.95 but I just put the link up before to the first one I found on a Google search … not checking price obviously 🙄
I don’t think it matters what the price is, the OP has disappeared.
Yes, Deta isn’t the greatest, but they do put a brown/blue ring around the terminals which helps if it’s not good light…..
Ie, under a kitchen wall unit
Reply to Anyone know this cooker switch? in the Electrical Tools and Products area at ElectriciansForums.net
Just wondering what everyone’s view on this is, if you’re mourning cooker or hob switch in cupboard close by. Would you still terminate into an...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Does anyone know what this is found when removing old mirrored wardbrobes
