Discuss Apprentice Electrician, discuss my tools! in the Electrical Tools and Products area at ElectriciansForums.net
27 years old, come from a domestic general building background; I have taken some pictures of my current tools that I take to site (week 4 as an apprentice)
The electrical company I work for do a lot of everything from domestic, commercial to industrial, I have a small list of tools that I really need but I wanted to know what YOU think are your go to tools when you go to work, can members draft me a small list of tools that they use more often than not when dealing with commercial and industrial please as I would really appreciate your input in building a fair selection of tools for future
IMG 20180826 191933 - https://ibb.co/dd4ML9
https://Upload the image directly to the thread.com/a/sDQIlAl
See it now through the link.
The gear you have is a good start. I would add......
Voltage indicator
Decent sidecutters, pliers, and long nose pliers. Go VDE for comfort and safety
Adjustable square
Metal file
Junior hacksaw
3.5mm rethreading tool
Spirit level
If you do bashing out, lump hammer, scutch chisel, cold chisel etc
You can add other stuff as you go along. If you have to borrow it twice then you need one yourself.
Suggestions might be.......
specialist cable strippers (tons of types out there)
bush spanners
socket set
rubber/plastic hammer if needed
punch down tool
ratchet driver
allen/hex keys
crimping tool
And if you get bitten by tool tartery, then you'll be buying every week for the rest of your career ;)
Cable croppers (already has side cutters), another pair of slip joint pliers, swap the adjustable wrenches for slim jaw (Bahco type), junior hacksaw, magnetic torpedo or boat spirit level, adjustable set square,, round file, flat or half round file, chalk line plum-bob or laser, red, blue, yellow ratchet crimper, straight tin snips, 10, 11, 13 & 17mm combination spanners, dumpy flat head screwdriver and draw wire.
I use scissors for all sorts, a lot for cutting labels to size from my label printer. As well I use them for cutting insulation tape so it is all neat. I also find them useful to cut cables when you can't get pliers or side cutters in. They are also used to score flexibles with the crescent in them. Very useful to have on you for cutting strings in cables and lots of other odd jobs. Oh I forgot:Electrician Knife.
i still got my own teeth for that.
* Flat ------- cut file.
* Half Round ------- cut file.
* ------- cut Rat tail file.
* Deburing tool (Bacho style)
* Engineers Square small, medium and large.
*Centre punch (spring loaded) = stops your drill wandering when drilling trunking etc...
* Wera big flat head screwdriver black and yellow with metal end for hammering home lock nuts. ( found in toolstation)
You seem to have a considerable amount of tools there Dan.
If you don't mind advice from an Old Man, buy what you can afford, don't buy stuff just because it lloks nice,"that's rich coming from a self confessed tool tart" that will come later when you have more spare cash than sense.
Seriously, get yourself a decent Electricians knife, couldn't make one out in your picture, there are plenty to choose from.
I found, I think they were CK or draper, Installation Pliers were very handy, they are about 40 quid, but they come with applications as follows :long nosed pliers, cable strippers and croppers for larger cables and a very basic crimp tool that can get you out of difficult situations, if you don't have a dedicated crimp tool.
One of those magnetic, extendable picker upper jobbies for when you drop something and it's difficult to get your had in to pick things up (provided the bit you dropped is ferrous of course, I also have a Klein Tools torch with a magnetic end and can double as a work light, it also has a glow in the dark ring on it to help you locate it in the dark. You'll soon be a tool tart, take it from one who knows.
judging from the length of your post, pete, it's obvious that you are suffering from "not bought a new tool in ages" syndrome. my advice is to get on the tinternet and find some new tool to satisfy your tool tart craving for another week or so. :D:D:D.
Reply to Apprentice Electrician, discuss my tools! in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I’m an industrial electrical engineer apprentice working at a wastewater treatment plant, I’ve been really enjoying the job which I’ve been...
Sorry if this is in the wrong place. I'm an electrician of 20 years. Starting out with domestic and commercial install work but mainly working in...
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
