Discuss arctic cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hi would arctic cable be ok for outside lights in conduit
cheers :)
don't see why not.--a little bit expensive perhaps.Arctic cable(flex) is designed to retain its flexability in sub-zero temperatures.But if your cables are inside conduit its unlikely that you will require ANY flexability.
what other way would you suggest
thanks
Depends on the installation.Where its gonna be.If you are in Canada maybe it would be a good idea,but in U.K. I don't think it will be required.Can you not use T&E inside your conduit? or Tufwire clipped direct,each installation needs to be considered separately.
yes i normally use t/e but i was not sure if its the best way i thought it might be quicker to use the arctic cable they are quite long runs and lots of bends
what do you think cheers
Reply to arctic cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I do love my job, and this is a fabulous job to be involved with, but jez the regs aren't clear on this type of thing. In a house, you have...
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi. Has anyone ever taking a feed from an outside light to use as a spur to fit an outside plug to plug in a plug in ring camera. The only feed...
What's best practice if running cable from garage out to outside double sockets? I'm re rendering that wall and thought it'd be nice if I could...
