Discuss Asbestos testing...... in the UK Electrical Forum area at ElectriciansForums.net
Hi, wondering if we should get something tested to see if they are asbestos. Currently they (wall tiles) are considered as being, but life would be easier if they definitely weren’t and we were able to drill them.
What sort of cost is getting them tested?
Thanks.
Is this in your house?
Is this a commercial premises?
If it's a commercial premises then I always thought they needed an up to date Asbestos Register.
This outlines all areas of the building and what was tested.
Anything not accessed or tested will be classed as containing asbestos until verified.
My advice would be call the professionals on this if unsure.
Cant help on this costing either but above is good advice in my mind.
I nearly got to the stage of testing in a domestic property. Think it was around £130, then multiples of £30. You can get some form of test kit, to test yourself with certain limitations, as far as I can recall. But never got to do it, so ignore what I've just said :(
I had some testing done in a domestic property - it was about £100 for what I think was a single sample. Have a look online for companies in your area, they might give a price online or over the phone.
Hi Chris, I use Airborne Environmental Consultants in Trafford. Less than £25 last time I did it for a 3 day turnaround (or about £40 for 24 hours). Not sure how much they charge if you need them to collect a sample.
Thanks for the replies.
Yes, I found AEC, they have s range of prices / times starting from £8 for five days up to £24 for 4 hours.
Thanks.
Also it’s comnercial but not mentioned in the report.
Reply to Asbestos testing...... in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Hello, I had an electrician install GFCI receptacles (as per their recommendation) due to my homes older electrical wiring. I also have...
Hi all. I'm currently building an island in my kitchen which will contain a gas hob. I've cut a trench about 60mm wide from the edge wall to...
