J
jonboy11
Hi, i am really struggling to find the relevant books and guidance notes to complete my assignment at Level 3 - 2365. Can anyone please help.
Discuss Assignment guide in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
c. is reversed phases so how would you test phase rotation and comparison to what the motor is requires?.6b describe the following symptoms the most likely electrical fault for - the outside lights above the entrance only turn off when the protective device is turned off??? answered by Tel
8a and 8b describe the most likely faults to occur in
terminations and connections where you join two cables together or connect a cable to an accessory since you are doing the connecting what may not actually happen?
and
instrumentation and metering at the intake position
At the intake you may be monitoring current, power, voltage, cost etc. the equipment is most likely to need to carry high currents as it is at the intake, or be sensitive electronic equipment. so what may fail?
9cdef
a number of areas within the nursery require special precautions to be taken during fault finding, identify these precautions in relations to the following
This is asking for special precautions so
c fibre-optic cabling What are the specific risks of having a cable with a powerful focused light source inside it?
d electronic devices When you have electronic devices which tests can cause problems or false readings?
e it equipment Which fault finding tests can cause damage to this equipment?
f high frequency or capacitive circuits What are the capabilities and vulnerabilities of your test instruments for these circuits?
11. a maintenance report details a number of situations. identify and explain suitable tests to determine the likely problem for each of the following situations
can't really summarise a guide here so
a. the lighting circuit was still live although the protective device had operated fused neutral not line how would you test for this?
b. a new machine does not function is there power to the machine, if so then faulty machine, if not then how would you check where the disconnection was?
c. a new three-phase motor is running the wrong way.
Reply to Assignment guide in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
