Discuss Attaching an earth tag to a vintage lamp holder in the UK Electrical Forum area at ElectriciansForums.net
Those earth tags appear to be designed to attach externally, probably to the base fitting, but would need to be secured with the correct size nut to be reliable for earthing purposes.
You can readily buy lampholders with integral earth terminals in all types of finish. An example is pictured.2019-04-07 12.05.00.jpg
You can get replacement brass lamp holders with earth terminals but you are likely to have thread compatibility issues as new holders will be metric and your studding imperial.
You would probably be best to buy a new antique brass lampholder with integral earth connection.
However you could retro fit an earth terminal to the lampholder.
If your parts are original they are likely to not be 10mm and instead 1/2" imperial. As Andy78 says the tags pictured are designed to go below the whole fitting where it attaches to the base.
I have in the past removed the earth terminal from a new holder (they are quite easy to remove) drill the base of the old holder and solder in place. This is a last resort in the OPs case as I had the luxury of bits and pieces of lamp holders.
Thanks everyone - just to reiterate - the earth tags I showed are really for lamp bases not to be introduced in a lamp holder. I don't really want to always use a new lamp holder because some of the old ones have beautiful switches and are also more nicely made than modern ones frankly. Therefore, my best option is to create a small hole in an old lamp holder and add an earthing nut either from a spare I have floating around or finding one to purchase. Correct? Thanks again!
Do you know where I could just get this small earth? I've looked at some spares I have with integral earthing tags and they are not removable...
Reply to Attaching an earth tag to a vintage lamp holder in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to rewire an antique metal standard lamp. It has been rewired previously, but not earthed..! One of the screws on the base has a...
5K
Thanks in advance for any help. I've got an old lamp (inherited from my gran) that I want to add a switch to and lengthen the wire. It doesn't...
I've got a security light which has two wires like a normal ceiling lamp (the first wiring diagram attached). I bought a new security light which...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
