Hi all,
I'm not sure if anyone can help but I'm looking for some advice on LED downlights and dimmer switches. First of all I'm not an electrician and I don't intend to try and carry out any changes myself I'm just looking for some guidance.
A few years back a local electrician completed an extension on my behalf and in the main living room he installed 12 x Aurora Enlite EN-DE82SN LED 8w downlights in conjunction with an Aurora AU-DSP400X Dimmer Switch 2 way. The lights have been working fine until about 6 months ago but a couple have started to flicker on the medium/high setting on the dimmer. I've checked with Aurora directly and they have confirmed the that the dimmer is only rated for 10 lights and not 12.
So the question is where do I go from here? Does anyone know of a similar dimmer that will run 12 LED downlights, or should I just replace the dimmer with a standard on/off switch?
Unfortunately the electrician who installed the original lights is no longer around.
Aurora did kindly provide me with the below link but it seems there are no standard dimmers that will run 12 lights.
Any advice would be gratefully received.
Regards
Dimming Compatibility - Aurora Lighting Trade - a lighting and technology company tailoring services and solutions to deliver Value Beyond Illumination™
We are a vertically integrated, global manufacturer of energy saving lighting solutions across all 4 Elements of Lighting: power, control, lamps and luminaires.
auroralighting.com
Regards
