Discuss Aurora Power One PVI 3600 Inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We have one of these and whilst getting a 'clock fail' fail message for a while, we also had to keep powering it down and up again each morning to clear a GFI error, and to get it to start generating. We've replaced the battery with the help of aurora power one inverter - https://www.electriciansforums.co.uk/threads/aurora-power-one-inverter.108599/ and set the time and date manually - and so far for three days all has been good and not needed to manually reset it, it is again working as is should. Installation company has gone out of business and the unit is out of warrantee by a few months. Thanks to google and it's link to this forum seems we've solved the problem - Thanks!
GFI means it is detecting an insulation fault on the DC side.
I am guessing a little, but since the battery change no GFI fault, part of my thought process has been it may be have been weather dependant, but the last few days it has been very wet here - and I'm now considering this to, perhaps, be a false indication caused by the low/dead battery - day five since replacing the battery and it's working as it should without having to power it down and back up to get it generating.
If it has been fine since then all good. If it was going to happen it would be far more prevalent when it is wet/damp so it looks like you may have got away with it with just a battery change. Result!
Reply to Aurora Power One PVI 3600 Inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all. Long story short - my Aurora P-One developed the common E031 fault. I carried out the repair myself (ex electronics teacher), replacing...
My original inverter installed in 2012 was replaced by ABB in 2016 after failing with a E031 error, my replacement is now getting around 6 year...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, my name is Kelvin. I'm a trainee hydraulic engineer in Indonesia. I apologize if this question has been answered before / if this question...
Hi everyone. Hello from Poland My uncle give me inverter Aurora Pvi 3.6 He told me when disconnect Pv panels the cable made a short circuit to...
