Discuss Aurora transformer in the Canada area at ElectriciansForums.net
A
Aerlingus
I recently had a call out to look at a lighting circuit that had an Aurora Dimmable Transformer 50 - 210 W/VA feeding two seperate spotlight circuits. One has three spotlights which are working fine. The other has six with three working fine and three just about lit. The transformer is therefor incompatible. Any suggestions as too what transformer to replace the existing unit?
u have that one tranny supplying all 9 spots or is there one for each circuit? if it's just the one then is no wonder it's struggling.
if the existing one's still working it'll be fine on the 3 spots circuit. as for the other circuit, gonna have to split it up if possible, 2x3, 3x2; don't think you'll find a tranny capable of running the 6 spots.
Reply to Aurora transformer in the Canada area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hello, We moved into our house 2 years ago and until recently the kitchen lights worked fine. The LED strip lights are on a dimmer switch, when...
I’ve recently moved into house and had an electrician out to install some new lights and shaver point in an en-suite. Problem is that the house is...
