Discuss Auto Electrical - LED Lights in the Auto Electrician Forum area at ElectriciansForums.net
Good morning knowledge base.
I have a project involving auto electrical (so 12V DC, or 13.8V on a good day) and LED lighting. I have a pair LED lights (total 60W) that I would like to be dimmable via a switch. The lights will therefore be fed by two circuits (one with a fixed resistor for the dimming) and each circuit will also require a diode to avoid back feed. The circuits will be activated by a changeover switch (SPDT) to allow selecting between circuits (dimmed or full).
So my questions:
1. What size resistor would I need to put in one of the feeds to dim the lights (say 50%)? I assume Id need to consider both ohms as well as capacity (in watts).
2. What size diode would I need in each circuit to stop the back feed?
Thanks in anticipation for your assistance.
So my questions:
Why would you need 2 circuits diode etc when you could just use a 3 pole switch ? or a dimmer switch ?
Reply to Auto Electrical - LED Lights in the Auto Electrician Forum area at ElectriciansForums.net
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
