M
mamba
This will be interesting.
Property 4 bed domestic within the M25.
Your task to day is to give the forum a price for the following recent requested works.
All earthing and bonding Complies
To supply and fit with high end spec.
1] Replace old rewire CU with new 12 way split RCD DB spec MK Supply and fit. Survey on present board shows no DB schedual present so no final desigination of final circuits not known - and the DB is wired as follows. x3 30amp red fuses as final ring mains and x1 30 amp radial in 6mm x1 15amp in 2.5 and x3 White 5amp fuses .....of which x2 have 2 x 1.5mm being feed off them so to be investigted further.
2] Install a 100amp DP fused or unfused isolator for single isolation of whole installation off 25mm tails on consumer side of meter.
3] Install 2 RCD 2way Garage Unit
4] Install 4 double sockets in garage as ring main I have spec metal clad. Total length of cable reg +/- 25 meters
5] Install 3 new lights [Lights are being supplied by client] in garage off present circuit, circuit to be extended as at present only a 1 point pendent present . Ceiling present so trunking will do.
6] Supply and fit an outside IP44 light LED with PIR.
7] fully test installation on completion and issue appropriate test sheets and results.
