Discuss Bad positioning or too fussy? in the UK Electrical Forum area at ElectriciansForums.net
sehs527
I'm a homeowner and looking for some advice. We have taken on a house renovation and had an electrician do a rewire. The second fix has just been done with socket faces now on etc. We've spent a little extra on faceplates but I'm not happy with the positioning with some of the sockets/switches. Thankfully most are ok but there are a few grouped together that are all spaced differently and it looks messy (pictured on studded walls): The fan switches are different heights (one I can reach the other I can't), they're different distances away from the door way/architrave.
I asked the electrician about it and understandably it's hard to be accurate during the first fix and I guess stud wall frames can affect positioning. Just wondering what you guys think?
We are all good at blowing our own trumpet and with many years of experience can throw a critical eye at most insallations
We could also know very well what a good and aesthetically pleasing installation should entail
Throwing my critical eye ate the installation I have come to 2 conclusions
Number 1 is unless you take care to get accessories sited well the installation can look a little amateurish
No 2 is unless you see various installation standard its difficult for that person to know good from bad, that includes electricians as well as others
If I were to site boxes for a switch on a stud wall, I generally use 5 inches from the start of the frame for my distance,( estimate the door lining width when no frame is fitted)
Any socket below would start at exact same distance be it a single or double
I have a habit (good or bad) of looking at items for level spacing and symmetry
In my own installations I make sure that trait is strictly followed and items are level spaced uniformly and symmetrical
Having stated the above, the photos are not anything unique to the the electrical industry
There might also be more to this than we, or the OP, knows. It's not unknown for a chippy to revisit and move or widen his door aperture slightly, after first fix of the electrics has been completed.
If there's a stud in the way, in a place where the correct positioning is important, such as the narrow wall in question, I either make sure the chippy doesn't put it there in the first place, or cut in a couple of trimmers, above and below, and remove the offending piece of stud.
He may have also not anticipated the style of architrave, and if there have been another inch of plaster between socket and frame it would instantly look better. I've seen a heck of a lot worse and from the surface you can't see what the other trades did to scupper the job!
Why not simply say that it's bothering you and can he can move the socket over a bit? Worst case, swapping to a single would look better if there's something in the way.
Interested to know how you do that if the wall is already boarded and skimmed
I think the answer to the op is yes!
If you specified where they were to be ie sockets halfway between door and corner, light switches 8" from doorframe etc then it is bad positioning.
If it was a more generic as in to the right of the door frame, etc, then you can't really complain, and it is a bit fussy.
In saying that, it looks like they just put the back boxes alongside wherever the joists were (wouldn't be surprised if they were just screwed into the joist at the side/top/ or bottom) which I would consider somewhat lazy and rough.
Personally, I (and I suspect most on here) would try to be consistent, and try to place fittings in aesthetically pleasing positions.
Anyone else use these.
Nah, they don’t look that great to be fair.
I normally use my laser level, then mark up and ask the client if they’re happy with the positions before I start chopping out.
Yes I use a draper one that does both single and twin it's not as big as the one you linked to, and it is very handy especially if used with a laser. Good in big kitchens ect, then just fly round with the multi cutter! Template even has the center marked.
Perfect size for dry line boxes and metal KO boxes.
like this. Didn't pay that much for it though!
Sy
Sy
I have that one as well, but find having a vertical level is sometimes handy
Reply to Bad positioning or too fussy? in the UK Electrical Forum area at ElectriciansForums.net
Hello. Had an issue a few months ago with a double electrical socket. One of the switches was stiff and sticking most of the time. I contacted a...
Hello, So I noticed my fridge had lost power, disconnected it and tried a hoover in the same socket and this also wouldn't work. I tried the...
Hi, I am not an electrician and looking for some electrical advice. We have had a new electric roller door installed at our warehouse. The door...
Hi all, New to the forum! Quick background on me: I have a degree in electrical engineering and spent many years working with qualified...
7K
