M
markthespark
Hello all I'm looking for some advice please.
I been out today to change a CU and when testing the 10mm water bonding I am getting a reading of 0.25. The stop tap is in the bathroom with all tiles around it, I can't see the bonding clamp so I tested to the nearest pipe.
I noticed that the pipe fittings near the stop tap are the push fit compression ones so I am guessing this is why I'm getting a bad reading.
My question is what should I do, I've looking under the sink in the kitchen and the pipe work seems to be all copper including the joints. Should I bond to here?
I plan to use this for my NIC assessment so need to get it spot on.
Cheers
Cheers
