Discuss Banning of Low voltage (MR16) lamps next year!! in the Australia area at ElectriciansForums.net
B
Bright Sparks
Hi Guys,
Be aware!
Low voltage halogen lamps set to be banned from next year | Lux Magazine
IRC lamps are not a straight replacement for the normal MR16 lamps as they 'burn' hotter (Upto 400 Deg C) and cause problems with the paint and bezels (Paint bonding causing the bezels to lock to the body and making lamp changing almost impossible).
LED is also not a direct replacement as they flicker too much and are not a 'true' retro fit.
Your thoughts please!!
and good riddance. bye bye unreliable lamp holders, transformers, etc.
Hmm, phasing them out next year but not having a replacement until sometime before 2016. Perhaps we are going to be kept in the dark on this:winkiss:
just need to get some GU10 lampholders in then.
I have never understood why anyone would want to try to light a room with about a kilowatt of torches on the ceiling when they could do it with a couple of 60W GLS lamps, but maybe I was brought up to be overly frugal.
From a different perspective I feel the 'ban everything brigade' are a bit too quick to jump in before a suitable replacement is found, like when they were saying we had to fit pendants which could only take CFL lamps and there were thousands of unhappy customers left either struggling to find 3 pin BC lamps or having to fork out about 10 times as much for special PL pendant sets.
Realistically what SELV alternatives are there to MR16s apart from LEDs (which I think have come on in leaps and bounds but they're still not everyone's cup of tea)?
Don't know where you get your kit from Tel but we have just changed 4 transformers on an installation we did 5 years ago and their the first one's to go albeit there on C-B us dimmers but even so that is not bad
don't install them myself. just get the call-outs to try and get them working again.
Can't wait till the tabloids get a hold of this news, they seemed pretty devastated when the ceiling heaters went. I bet the anti change folk won't be taking into account the costs of calling a electrician out once a month to fix their 'traditional' burner
When one is faulty I always recommend to customer to change all lampholders to GU10 and fit LED's. Got a mountain of spare parts for the MR16's now though:rockstar:
I cant work it out,, global warming,, we all use too much electricity, the end of the world is here....
So ban them power draining lamps!!!
then you walk into any store that have 30+ high bay fittings with 400w mbfu lamps burning away for 20hrs a day just so my sunday joint looks nice!!!! then they ban us from using filerment lamps and fause us to use crappy cfl lamps... i think the goverment must employ people who's job it is to find stuff to ban!
cant tell you how many times a customer has told me that they were told by the guy that fitted them that low voltage meant low energy and have been blissfully unaware how un energy efficient they are. Its happened so many times that some of the guys fitting them must have believed it themselves. Nothing more than a job creation scheme so you cab come back in a few years and replace the Tx.
Ive fitted a few that the customer has bought, trick lights etc, and part of sauna kits, things like that but the sooner they are banned the better as far as Im concerned. SMD LEDs, thats the way forward
never mind the stores. just look at all the government offices that are lit up like the final scene in close encounters all night long.
I`ve seen a few LED replacements for standard 4/5/6ft flourescents advertised, anyone tried those?
Yep, but going back 2 years now so I am sure they have progressed a fair bit. At the time I felt the light was a bit too direct. Fitted LED High Bays around the same time and same thing, light just not got enough spread (IIRC The High Bay cost about £400 a pop!)
I'm quite happy to recommend to a customer to change a downlight to LED, but wouldn't with a Fluorescent or discharge lamp as personally don't think the cost justifies it just yet.
Reply to Banning of Low voltage (MR16) lamps next year!! in the Australia area at ElectriciansForums.net
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
Hoping for advice that isn't "check each outlet" but if need be, I will... Bought a house a few years back (1960's build). Home inspector advised...
S
Hello, I wonder if someone can help me here. My understanding is : Leading edge dimmers are suitable for mains GU10 halogen lamps, but need to...
scanner
S
"Hello All", As this might be seen as an insignificant `problem` I tried to post this in the DIY section but there was no `New Thread` button...
Low-voltage halogen lamps are to be banned from next year under draft legislation drawn up by the European Commission, Lux magazine can reveal...
TomandLesley
T
