Hi,
Is anyone aware of a basic test I can carry out at the Canbus level? I want to see whether the fault lies with one of the vehicle controllers (ECU on rear "Haldex") or whether the vehicle is either not talking to it or not receiving it's response.
Essentially the vehicle tests all appear exactly as if the module wasn't there, in fact the results are exactly the same if it's disconnected. However I have tried a different ECU so the fault must either be something on the vehicle side stopping it communicating, or something in the assembly that causing the ECU to shut down.
Thanks, Tony S
Thanks, Tony S
