Discuss Basic lighting controls question. in the Industrial Electricians' Talk area at ElectriciansForums.net
M
mhmd_01
hi this is my first post :)
Before i ask the question i would like to point out that i am just a kid so dont go onto really techie stuff with me.
well my question is that i have bought 2 dimmes, 1 double and 1 single, meant to go on a ceiling + wall candle bulb lights (double) and a fluorescent wall light (single). So they tell me they cant put the dimer on the fluorescent because of some transistor thingy. They have put a normal switch there instead, they have also put a normal switch for the ceiling light so that now has a dimmer and switch controlling it. So now i go and tell him to replace the normal switch for the ceiling light with the spare dimmer and he goes that you have to have a normal switch on one side, and you can only have 1 dimmer. Is this true? Sorry if i confused you, i often do that to people :(
hi,
i think you must have 2 way switching for the ceiling light ,if so ,then yes one of them will be a normal switch,the light will still dim ok,
atvbitwww
oh and ,no you cant put a dimmer on the flouresent
yes ,if its a one way switch doing the light ,just swop it ,if its 2 way one of them has to be a normal swich and the other a dimmer.
so unless ive compleatly missunderstood what your on about ,dont see any problems
atvbitwww
hi,
atvbitwww
Depends upon type of ballast used as you can know get HF digital ballast which you can use with a dimmer switch.:rolleyes:
i stand corrected,have you got an h.f digital ballast which you can use with a dimmer swicth ,if not either get one or dont put the flouresent on a dimmer,
astvbitwww
yeah well, ilooked through its fitting instructions and it says to not use a dimmer, bummer
theres no reason to call Rumrunner a bummer, he was only trying to help:p
just because you dont have an HF digital ballast theres no reason to question someones sexuallity
even if it is Rumrunner;)
fpmsl.............................:D:D:D:D
i would tend to call out an electrician. there is too many of these stupid posts on here when people are trying to do a qualified job themselves.
Hi all,
This whole thing about h.f digital ballasts,is very interesting ,bit of an overkill for a domestic property maybee,but for commercial or offices etc ,i think they will become common place before to long ,technollogy is moving so fast now ,i am a dinosaw as far as technollogy is concerned and had never even heard about h.f digital ballasts before ian corrected my post yesterday ,so allthough the original question was from a non sparky ,it helped me ,big time .
tap "h.f digital ballasts for flouresent lighting" into google ,this whole subject is facinating and gives us an insight to which way the trade is going
atvbitwww:)
Hi all,
atvbitwww:)
bummer
What? you thought... Haha i didnt even know what that means! i just read bummer on other forums and thought it means like "aww crap!" ha ha sorry
Reply to Basic lighting controls question. in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I have a single wall switch powering 1 light and I want to add a separate light and change to wall switch to a double to power them both...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
