I tested a non working outlet with receptacle tester and it said open neutral. Turns out that the neutral wire was loose. BUT, in order to shut off the power I had to turn off 2 circuits. Inside the box was only 2 wires, black and white.
So the open neutral is fixed but how many other problems do I have now? None would be a good answer but don't think it would be correct. Thanks in advance.
