Hi
I need some advice should I try to fix this isolation switch for the extractor fan or buy a new one. The switch part of the product has come off. It seems it was previously attached into the plate using some resin of some sort. Over time it became loose and has come off. I can manually insert it back but the switching does not happen now as I believe due to the resin having come off it is not forming a proper contact with the circuit below it in the wall plate. Can it be fixed easily or not?
Thanks in advance for any advice.
regards
Higgs
regards
Higgs
