Discuss Bathroom extractor isolation switch/PIR in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Small job for a landlord friend of mine having problems with tenants turning off the bathroom isolation switch and causing damp to the property, Can I replace the fan isolator with a pir so if their would like to isolate the supply their would have to do it from the consumer unit any advise would be great thanks
Reply to Bathroom extractor isolation switch/PIR in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
