Discuss Bathroom fan isolator in the Electrical Tools and Products area at ElectriciansForums.net
B
BigBadBry
Hi,
Im fitting an extractor fan in a bathroom and was looking at using a 3 pole pull cord as isolator/switch, can someone point me in the direction of where to get one from, ive googled it but can only find one to order. Also is this acceptable as i always thought that the isolator had to be fitted outside of the bathroom.
Thanks.
hi thats a new one on me never seen tp pullcord normally put tp switch outside door
it sound odd the switch is for isolation for maintenance the reason for it being high
level cant see the point of pull cord that that can be switched on with little effort
i am waffeling now but you get my gist
well just found them tp fan pullcord tlc do them well with that i am off to bed
Hi there
A 3 pole pull cord isolator is fine as long as the extractor fan is situated in the bathroom as these are not lockable... well i havent come across any.Also needs to be in zone 3, if you have an in line fan in the loft it needs an isolator adjacent to it, unless you have a lockable 3 pole plate switch in the bathroom... hope it makes sense.
Reply to Bathroom fan isolator in the Electrical Tools and Products area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
