Discuss Bathroom light connection query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
NicWright
Hi I'd like some advice please!
I'm trying to replace a broken wall light in my bathroom. The new light has a small, screwed box (see photo) to connect the live and neutral wires but the grommets are tiny and look like they'll only take one thin wire. I have 2 thick live & 2 thick neutral wires coming out of the wall to connect. I notice on the light that the 2 neutral wires from the bulb holders at each end go into a separate, rubber covered connector with a single wire going into the screwed box.
Is this the way I should go? Or what is the best way to do this please?
FYI - The new light will be next to the shower & is IP44 rated.
Thanks for any advice you can give me on this. Nic
your new light should come with instructions and its these you need to follow, please explain further about been next to shower ...what zone does it fall in as this will gauge whether the fitting would be suitable for the job.
Disconnect that pathetic connector block in the light, throw it away and replace with a proper one, I would recommend a 10 amp minimum rated porcelin block in that light with heat resisting Sleaving over the phase conductors, I keep porcelin blocks on the van as standard due to manufactures quality being very poor as standard these days.
think they use those silly boxes to meet the IP rating of the fitting somehow ?
Really? you may well be right, however IMO providing the lid has a Proper seal and can be IPX4 Rated then I cannot understand why those connectors need to be used, assuming any rear entry by cabling is properly sealed also.
It's beside the shower cubicle so zone 2 as I understand it!? It does come with instructions but I don't see how the cable will fit through the hole to enable me to connect it as per the instructions.
do as mike said get rid of silly connector block and use a proper sized one 10amp
- - - Updated - - -
- - - Updated - - -
Welcome to our world when a customer buys some cheap crap from Ikea etc (disclaimer... cheap crap is also available at other diy stores)
the fittings not Double insulated (visible earth), and the piece of crap aint IP raited, the pull swich is visible in the picture. as above ditch the block and fit somthing more suitable for your requirements..
Edit that, is that pull switch sealed up, i can see silicone or somthing
HAVE TO GOT A SUITABLE ENCLOSURE FOR THAT LIGHT FITTING. HERE'S ONE I MADE EARLIER.
media.nl
Reply to Bathroom light connection query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Hi, Just looking for some advice. In a bedroom there are 5 downlights on a dimmer switch. When turned on, every now and again these lights can...
