Discuss Bathroom Light wiring help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Basically I am trying to wire a new light into a bathroom.
The old one was removed and the wires were left connected in connector blocks. All lives together, all naturals together, all earths together, and then the black (neutral) from switch and a yellow from a 4 core cable were together. Please can anyone tell me how I connect this properly. Is the black from the switch acting as a live? I'm really confused thanks.
Perry
It sounds like the black is a switchwire and should have some tape or sleeving on it to distinguish it as NOT a neutral.
The yellow also is a switch wire going to an extract fan.
You should take photos or draw a diagram when you take the old fitting down so you know how it goes back.
Disclaimer:
This is how I see it. I could be wrong.
Sorry I had no before pic as they were already taped up together when i moved in.
Basically from the switch I have just the live and neutral(possible acting as a live switch wire) then I have 3 standard cables coming from other lights in other rooms and then one cable with live neaurural and a yellow cable(possibly extractor fan switch wire)
What I said above is probably correct, but without seeing it, it is guesswork.
We’re really not meant to hand out step by step instructions just in case your house burns down next week or you get a shock, fall off your ladder and break your self on the toilet pan.
So, with that in mind, I would advise you ask a friendly local electrician to pop in and give you a hand.
Should cost no more than a 4 pack of stella
Hi Perry and Welcome to the Forum.
Do you have any test gear? Please remember that some of those conductors are live.
Perry
yes it should be marked with red and so should the yellow wire, the 4 core wire will be running a fan
Reply to Bathroom Light wiring help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
