Daveyboy
Hi, guys in a bathroom would fitting ip44 downlights be acceptable above a bath? I know the zoning is acceptable but would moisture affect them?
Discuss bathroom mains voltage downlights in the Australia area at ElectriciansForums.net
Digit | Protection from solid objects | 2nd Digit | Protection from moisture |
0 | No protection | 0 | No protection |
1 | Protection against solid objects with diameter greater than 50mm | 1 | Protection from dripping water |
2 | Protection against solid objects with diameter greater then 12mm | 2 | Protection from dripping water when tilted upto 15 degrees |
3 | Protection against solid objects with diameter greater than 2.5mm | 3 | Protection from spraying water (rain) |
4 | Protection against solid objects with diameter greater than 1mm | 4 | Protection from splashing water |
5 | Dust protected | 5 | Protection from water jets |
6 | Dust tight | 6 | Protection from heavy seas |
7 | Protection from immersion in water | ||
8 | Protection from continuous submersion in water |
Reply to bathroom mains voltage downlights in the Australia area at ElectriciansForums.net
