Discuss Bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
Changing a pull switch for shower is this notifiable cause it's a bathroom or mw
Has the existing one melted then?
If so, I'd thoroughly recommend tidying up cables, thru crimping and then fitting a blanking plate to the patress. Saves exactly the same thing from happening again.
i have, not really failed just the switch doesnt always activate but ive only seen it onceOr fitting a Crabtree 50A version - never seen one of these fail!
I have to agree regarding the quality of those units, their screw terminals are however subject to the same expansion and contraction as the screw terminals in a cheap bakelite isolator, a by-product of the heat generated by the current (teaching you how to suck eggs I know Murdoch).
I think the reason they are "more robust" is down to the fact that that entire design allows the installer to use up to 10mm cable, and be able to tighten the screws properly, and not "disturb" the connections when the cover is screwed back on - unlike most other badly designed 45A pull switches!
Was that covered under your guarantee !
Reply to Bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
