Discuss Bathroom wiring advice in the Lighting Forum area at ElectriciansForums.net
benhurr
1. Does every powered item in bathroom needs fused spur outside?
2. Can separate RCD be required even if the supplied power is under CU RCD (for example whirlpool bath or underfloor heating)?
Please check and comment rough wiring diagram (there is no details like L N G etc, just rough requirements idea)
I am getting quotes for electricians and what to make sure they are doing the right thing. From my past experience most of a cheaper trades persons would cut a lot of corners and it result in further fixing etc.
  • bathroomwiringdiagram.pdf
The simple answer to question 1 is no, not everything requires a fused spur, depending on the appliance other types of isolator may be necessary.
Normally a seperate isolator is not installed for lights or a shaver socket, they simply connect to the lighting circuit in the normal way.
We can't tell you how the electrician you use will do things as we all work differently and have our own way of doing things within the regulations.
The best way to avoid the cheap tradespeople cutting corners is to not use cheap tradespeople.
It may be worth you posting a request on here for an electrician.
there are quite a lot of us here!!
Does the underfloor heating requires separate rcd or cu rcd is enough?
Reply to Bathroom wiring advice in the Lighting Forum area at ElectriciansForums.net
Does bathroom light circuit required to have dedicated circuit or is it ok to be wired to other light circuits? I am getting quotes for...
Hi everyone, please advice and comment on the attached wiring diagram for a kitchen. There are mixed opinions on the need for FSU-s and number of...
4K
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
