Discuss Battery amps and starting in the Auto Electrician Forum area at ElectriciansForums.net
Siman
I have a 100ah battery 900cca
I want to install an airflow fan in my vw t4 in the rear for my dog, fan is 12v dc, 10 watts, 0.8amps, How long can I run it with engine off before van won't start?
a 60AH battery will give you about 40 hours before showing signs of failing. assuming no other loads at same time. far longer than your dog can't do without food and water.
Hi,also you may need to consider the reason for needing it, If it is merely ventilation,even that size of fan,may be over-kill. If you intend to have air-change,and not just wafting around stale air,then you will need an "in" and an "out". A ten watt fan will exchange all the air in a vehicle that size,very quickly,and it will be swapped for the air outside,at the external temperature (4 degree out=4 degree in= 4 degree dog)
I have lots of pals in the van/camper/dog transport job,and the best trade-off of heat/ventilation etc,seems to be trickle vent high up,and insulate the van.
Just don't permanently obscure the wiring looms in a T4.....because at some stage,you WILL need access to it ;)
Reply to Battery amps and starting in the Auto Electrician Forum area at ElectriciansForums.net
Long standing issue on my VW Transporter T4. First noticed under 'lockdown'. Battery drains flat if stood more that 3 - 4 days. Industrial spark's...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Good morning all. Before I start I am not an electrician and am relatively new to this topic. Current set up Axpert 5.5 Kw inverter, 7 x 420...
Looking for advice for how much power I can reliably get from a dual battery system please (note it will be installed by a professional, I am just...
I have an interesting starter circuit issue on a 2001 Toyota Celica (that won't start). If I have the starter out and have the main positive...
