L
long512
Hi All,
looking for some advice on car battery's. We have opened a clay pigeon shooting range at our farm, and my brother is paranoid about how long we can use these batteries before they start to loose the power to work the traps. they are just standard car batteries (new) some 40ah and some 70ah . we run the traps for about 3 hours and they pull around 5 amp max each time they fire but only for around 4 seconds. its hard to say how long in total they continually run but no more than 1.5 hrs i would say???
questions,
1. what is the best way to test/measure the batteries before we remove them to charge?
2. does it cause damage to the cells charging them to much ie after every time?
any advice would be greatly received, i probably need to give you more information, motor size power ect if so just ask i'll find out tomorrow!
also, we are thinking about supplying them from a 12v transformer ( a big one ) but i'm worried about cable size. we have a huge roll of mullticore 2.5 tri rated but when doing my calculations i fear its not big enough? there are 20 traps in total and at times would be 3-4 pulling supply at the same time.
the cable run will be at least 50m they say you cant have more than 3% vd over the run??? using an online cable sizing guide it recomends a cable 20mm to keep voltage drop bellow 0.036v??
what am i missing? my brother recons 2.5 will be big enough coz his mate says so??
cheers allister
questions,
cheers allister
