Is it possible to power a vending machiene with some form of battery power for a 24 hour period!
Info I have on vending machines:
Most run on 115 volts at 10.5 amps. Power usage is estimated at 3.1 - 4.4 kWh/day for lighting and 3.5 - 4 kWh/day for refrigeration.
Cheers for any help.
OK, just doing some simple maths on this:
A LARGE car battery might be 12V, 100Ah. That's 1200Wh of energy, or 1.2kWh.
Your figures add up to, say, 8kWh/day. So if you could use the whole rated capacity of the batteries to run an inverter, you would need 7 large car batteries for a day's power.
But you can't use the whole rated capacity of the batteries or they'll have a very short life. Also the actual capacity reduces with age and use. Plus, the inverter won't be 100% efficient. So, taking all that into account, you might need 15 or 20 batteries for a day's use. Plus another couple of sets charging up. So perhaps 45 to 60 large car batteries.
I'm sure someone will correct this if I've made an error.
By the way, vending machines are going over to LED for lighting. So I would expect the lighting figure to be quite a lot less than quoted.
Edit: Thinking it over, the batteries would take up about the same amount of volume as a typical vending machine.
