Discuss Batton light installation in the UK Electrical Forum area at ElectriciansForums.net
Dbaxter79
I am replacing an old light in my garage with a new LED one the problem I'm having is the light is flipping the fuse when I turn it on, there are 2 sets of cables to the light but one to the wall switch I think originally there were 2 lights in the garage but now just 1. If I connect both set of cables it blows the fuse if I split them 1 will work but the light doesn't turn off and the 2nd does nothing
In future you should make careful note of how a light is connected before disconnecting it.
The most likely answer to this is that of those two cables one is the incoming feed and the other is the cable running to the switch.
Reply to Batton light installation in the UK Electrical Forum area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
