• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Best place to advertise for help on a job in the Electricians Jobs area at ElectriciansForums.net
This person requires some work. They've hopefully explained their skills and qualifications and what area they're in. Otherwise, what's the bloody point?
Hi all. I have a couple of jobs coming up that I will need a helper to help out with - general electrical stuff like pulling cables, cutting channels, drilling holes, stuff like that. Where is a good place to advertise? And what is the going rate for a jobbing sparky (eg NVQ level 2) or similar?
Many thanks.
i'm sure there's a member from Derby looking for work. check out threads over last 2-3 weeks.
there's a guy here from a few months ago.
Many thanks.
NVQ Level 2 isn't sparky grade - that's Level 3.
Many thanks.
Ask the electrical department of a local college, the head of department would have a good idea of his best students. EG: ones that don't mess about as much.
Hi and welcome,
I have moved your post to the Electricians Looking For Work/Jobs forum.
Thanks for your post :)
Reply to Best place to advertise for help on a job in the Electricians Jobs area at ElectriciansForums.net
This has probably been asked 1000 times. I am just coming to the end of my apprenticeship and was interesting in trying to work abroad. I was...
So I have tried applying to every electrician mate/improver jobs there is on every job websites and I got a few calls saying that they want guys...
Hi guys wonder if you can help. Just laid some electric underfloor(not going to connect it myself) it’s the loose lay stuff thin stuff. I spaced...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi all, hope you're well I'm hoping to find an electrician around Leicestershire/Northamptonshire that would be willing to allow me to come out...
