A
AndyHunt
Before I begin, I put my hands up and admit I'm neither a sparks by occupation, nor a qualified domestic installer, nor Part P qualified. I do have a degree in Electrical and Electronic Engineering, and I spent many years doing temporary lighting installations for theatrical shows, concerts etc - so I am fairly competent and not entirely deserving of being branded as "just DIY".
I'm currently having my own house renovated and I've engaged a "proper" electrician to undertake all the Part P notifiable work, so don't worry, I'm not cutting corners etc, I just want to compass views on "best practice" for my own interest.
So - I have a standard domestic lighting circuit, on a newly installed fully compliant board, and I'm having a small IP66 LED light put into the shower area as a feature. It's an Aurora product in case anybody's familiar. Aurora have provided an LED driver which has 230v input flyleads and low voltage output flyleads. The intention is to mount the driver (which is only 35x25x20mm) on the vertical wall behind a fitted wardrobe in the adjacent room, with a removable inspection panel in the back of the wardrobe (the in-line extract fan is there too). Currently, there's a run of flex going from the LED location to this wall location, and the twin & earth feed from the light switch also runs there.
The question is - what's considered best practice for actually wiring up the LED driver? To be honest I don't know what the overload protection of the LED driver is like - perhaps it's adequate - but a circuit with a 6A breaker seems like a lot to me for a tiny LED. Perhaps this needs addressing, perhaps not.
A few options occur to me:
1. Terminate the T&E in an unswitched fused spur plate with a 1a fuse, mount the driver on the wall next to that plate and choc block / WAGO the low voltage side next to it;
2. Put the whole LED driver inside a surface box, choc block / WAGO the 230v and low voltage sides inside the box, put a blank plate on the box and bring the low voltage flex out the side - maybe with some cable ties in the box for strain relief;
3. Wall mount a standard junction box for the 230v side, wall mount the LED driver, and wall mount a choc block for the low voltage side....
... None of which are "wrong" in my view (although some may argue, or I may have overlooked a regulation in which case I apologise and please enlighten me) - the question is which one (or any other) is "best"?
I'd appreciate any constructive feedback.
Many thanks.
Many thanks.
