Discuss Best soffit lighting in the Lighting Forum area at ElectriciansForums.net
is there any chance of water or condensation getting into them from the rear?
although they say IP65, this only applies to the front of the light, IP20 is the rating from behind.
Combination of both!
7.5w IMO is too powerful for soffit lights and the 4.4w fitting is 4000k only (I would personally go for 3000k)
If it was for myself I would use fittings with replaceable lamps but the integral lamps ones are all pretty similar TBH, just a matter of finding ones with the output you require!
ihaveused the V50s on a few jobs. customers delighted with them, esp. asyou can select warm or cool white.
We installed these into the soffits of over 10 properties over the last two years. 8W versions also available and I believe there's a CCT version as well now.
As someone mentioned above, don't go too bright or it looks cack (technical term)
Reply to Best soffit lighting in the Lighting Forum area at ElectriciansForums.net
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
Hello, I'm new to this and I'm looking for someone to review my wiring diagram. I'm not sure if I need a fuse block because I'm using an XTM...
Electrical2Go - Mega Downlight Deal - Don't miss out! Taking place from August 18th to 20th, we're offering an incredible promotion for...
Ive got an old T5 (or4?) fitting to change to LED, but its built into the kitchen cabinet between two shelves of glass. Is there any like this...
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
