Discuss Best way to drill timbers in the UK Electrical Forum area at ElectriciansForums.net
Morning all
What ways do people drill out there timbers? I have started using an impact driver but its very noisy!!
My makita combi drills are ok but dont like doing it for long until they heat up.....
Yes i melted the brush holder on mine doing that, the trick is to put it in first gear meaning the motor and fan are going a lot quicker.
Or get a brushless drill, they don't have the brushes to overheat. But still use 1st gear.
As above an impact driver is not for drilling, only for screwing. Also re the noise thing, use ear protection, you only get one set of ears
An impact driver is designed for a specific task...it does that job well.
The words "impact" and "driver" are clues!
An impact driver doesn’t know the difference between a 10 x 2 wood screw and a Bosch flat bit with screw going into a joist - they don’t got no brains!
Ear protection is the answer and an apology to those around for the next 3 minutes of ugly noise!
Reply to Best way to drill timbers in the UK Electrical Forum area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Quite a few new builds are popping up locally in my area. I have noticed that they are not even being first fixed until the buildings are...
Most of the work I do is additions and alterations in domestic properties, and other than swapping accessories and lights in new-builds for...
