Discuss Best way to drill timbers in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Morning all
What ways do people drill out there timbers? I have started using an impact driver but its very noisy!!
My makita combi drills are ok but dont like doing it for long until they heat up.....
Impact drills are not designed for timber drilling, use a drill with a speed suitable for hole diameter, small holes fast, big hole slower. Flat bits are cheap and work well unless you are boring deep holes when auger bits are more suitable. The multi flute auger bits require a high torque drill due to increased friction of the cutting flutes over a flat bit they are also much less forgiving of clipping screws or nails in use.
These work well with an impact driver but with a standard drill they tend to stop just before they exit the joist as the screw tip protrudes and is unable to pull the blade into the wood.
Blunt ones certainly, sharp ones.. no problem.
I use a variety of different Irwin flute bits and my Dewalt dcd996 Combi. Eats everything I throw at it.
The flute bits that are designed to withstand hitting nails are OK I use these when appropriate.
I use the impact driver and stubby flute bits when space is tight.
The Irwin extension bars designed for these bits are pretty damned good too.
I find that the slightest push is all that is needed to finish the last mm off using a combi drill.
when drilling through timber you must pull back to clear the drill bit and it go through quicker and will not stop until you are at the other side of the wood .
I beams everywhere :)
I remember going to a new build (being built by a gang of Bulgarian builders). They were using the wooden FinnJoist(?) I-beams. These are made with a number of push out holes in the beams.
This makes it a doddle, as a pop with a hammer on each joist, and there's your cable run.
HOWEVER
the joists are not symmetrical and
the muppet builders had not set out the beams so all the holes aligned. Not a problem for me as the cables can zig and zag. The plumber, however was not amused. (He was from Poland).
25mm sds auger bit in 110V makita. last job i did, the joists were 4" thick. 100+ holes in 1 hour.
HOWEVER
Never had a house where the knock out holes lined up.
Reply to Best way to drill timbers in the UK Electrical Forum area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Quite a few new builds are popping up locally in my area. I have noticed that they are not even being first fixed until the buildings are...
Most of the work I do is additions and alterations in domestic properties, and other than swapping accessories and lights in new-builds for...
