- Reaction score
- 186
Hi Gorgeous people.
Hope you are all well and surviving!
Just curious to others views on redircting an oven cable which has to move (so it will not be over the hob) but with no access to the above floor where it comes down from (which is a tiled bathroom).
Ideally the new switch wants to go on the left hand side near to the window wall. The question is, How would you do it trying to keep to zones, not hiding an extending connection in the wall etc?
Worth a note: on the other side of the wall is a utility room.
The only viable option I see is to lay a new cable under the floor and up. Which is a bigger job and may be problematic as the kitchen is an extension with only inches below it (not sure there's a straight way through).
Anyone done similar recently with good results?
