Discuss best way in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bahco
mate of mine has got a utility room with a washer dryer and a freezer in, fuse spur on the ring which feeds 1 2g switched skt, which runs the washer and dryer.
double socket near on the ring which runs the freezer, the fuse in the spur keeps blowing cant take the dryer and the washer at the same time.
is the best way to plug the washer and the freezer into the 2nd socket then the dryer ito the socket fed by the spur?
any other idears?
cheers lads
If the fused spur is part of the ringmain & only supplies the double socket that the washer & dryer are plugged into, why not remove it & replace with a socket. the appliances do have fused plugs I take it.
yeah thats what i said to him but the fuse spur is above his worktop and he does not want to see cables above.
the socket which the spur runs is below the work top as is the 2nd socket, sorry my fault for not explaning properly in the first post
any idears?
sounds like he wants his cake and eat it
if he dont wanna see cables above, then he can only use his washer OR drier
its give and take!!!
if the freezer socket is on the ring, and i presume is under the worktop, why not just spur off that to another socket for the washer or drier?
Reply to best way in the Industrial Electricians' Talk area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
HI All, I am building a new house (self build) and have my part P so am running the cabling. My reading of the regs says that any appliance of...
4K
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
I'm sure this has been asked before, but I just want to confirm: Currently I have a spur leaving a socket in the bedroom, into a 13A Switched...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
