• Welcome to the new forum. We're now hosted on ElectriciansForums.net rather than ElectriciansForums.co.uk - Chat about the forum upgrade by CLICKING HERE
Welcome to our Electrical Forum - We started out providing electrical advice just for the UK - But now we have specific advice for the USA too! - Register for free and share American Electrical Advice.
Discuss Best ways to monitor solar pv system and heat water? in the Solar PV Forum area at ElectriciansForums.net
Status
Not open for further replies.
compmad1
Active EF Member
I'm uncertain regarding the relative advantages and disadvantages of two systems:
1. Elios4you to monitor the system and the linked Power Reducer to heat the hot water.
I have not been quoted a price for this system. Can anyone advise?
2. A Geo Solo PV Monitor and an Immersun Unit.
I have been quoted £150 for the monitor and £500 for the Immersun.
Any thoughts greatly appreciated. Thanks.
compmad1
Active EF Member
Meant to say that I have read on Amazon that the Geo Solo PV Monitor and Immersun Unit are incompatible. Someone said that they needed a refund in the end as the problem could not be resolved by the manufacturers.
Also I'm confused by the difference between a The Chorus PV display and a geo Solo PV Monitor . The first one seems more expensive, and have read a price on their website of £230. The second one is what I have been quoted for. Do these products do the same thing? I need to be able to see what my roof is generating, and what power I am drawing from the grid.
Thanks again for any advise.
SibertSolar
Solar Guru
We have a bias, naturally, towards the Elios4You platform but our decision to represent Greenologic/4-Noks was one taken after months of deliberation and due diligence. The RRP for the Elios4You + Power Reducer, accordingly to Greenologic, is £630. However, this is not the trade price we offer for the kit. If you want to have a look at some of the manufacturer's documents, as well as some potential useful comparison/technological info then you can find some here. I understand if this post is removed by the mods though, of course.
compmad1
Active EF Member
I've just been quoted £500 + 5% VAT for this system. Seems cheaper and more refined than the other system.
Gavin A
Electrician's Arms
Solar Guru
we've installed most options, and the elios unit seems to be head and shoulders above the rest if you like gadgets. Possibly a little complex for those not too technically literate - ie I'd never install one for my gran who refuses point blank even to consider learning to use email.
compmad1
Active EF Member
I love gadgets, so it would suit me down to the ground. Thanks.
Greenday
Regular EF Member
Ive heard of problems with the Immersun unit but never actually had a problem on any of our installs. We now favour the Solar iBoost as it's wireless connection means less disruption on the install. We combine this with a Solo II with bridge to a router so you have true online monitoring and record keeping anywhere. We have used Wattson's with Optimmersion in the past and these work well too. Horses for courses I suppose!
The Solar King
Electrician's Arms
Solar Guru
The new Immersun offering should overcome the issues mentioned. It also has a wireless option if required. As it no longer uses burst fire, it should be compatible with other devices.
There is a price increase over the old unit.
SibertSolar
Solar Guru
Is the new Immersun available yet? What technology are they now using, if they are moving away from burst-fire? What are they planning to do (if anything) about their burst-fire units already installed? Will it be independently CE tested/marked? Will it be EMC compliant for domestic and industrial norms? Independently lab tested, or in-house?
pwboston
Regular EF Member
You seem to be thinking they are replacing Immersun 1 with the new model. Its on top of the old unit.
When i spoke to them the mark I will be an economical unit to compete against the cheaper ones out there and the new one will have extra facilities, such as wireless options.
At least that is what they told me a few months ago, maybe things have changed since then
The Solar King
Electrician's Arms
Solar Guru
It's PWM. The price with wireless will push it toward that of the Elios.
I was told it is fully compliant, but as to testing and certification, you would need to ask 4eco.
Worcester may know more.
Gavin A
Electrician's Arms
Solar Guru
so they want to continue to flog a non compliant model, which if you read G83/2 arguably breaches those conditions if it's viewed as part of the solar installation, never mind it just being against the flicker regulations anyway.
I was quite interested in the new model, but tbh I've got problems dealing with a company who're this cavalier when it comes to compliance with basic regulations such as this one that are in place for very good reasons - ie to protect epilepsy and migraine sufferers from the impact of rapidly flickering lights, as well as the potential impact on other electrical kit.
P
puddy
If you are keeping cost down the geo chorus pv 2 is the best one. The chorus pv 2 tells you if you exporting or importing from the grid the cheaper model doesn't show export amount.
So far I have tried the fronus data web logger2 solar-log 200 wifi and the geo chorus pv 2. Only the Geo chorus 2 and and Elios4you gives import and export to and from the grid and the geo chrous pv 2 the cheapest, The geo can be installed without any tools plus you don't need to switch off the mains power. If you are the homeowner and unsure contact a electrician first
Status
Electrician Talk
Electrical 2 Go - Electrical Supplier and Electrical Wholesalers
Electrical Insurance
ElectriciansForums.net (formerly known as ElectriciansForums.co.uk) was setup in April 2006 to provide free electrical advice to both professional and DIY electricians. Whether seeking advice for auto electrics, trying to find electrical installation condition reports (EICR) form downloads, or whether you're here just to talk to other electricians; we've been a first-choice website for tens of thousands of sparkies for well over a decade.
